Which Green Box? Can I find out? Does it Matter?
Leapy
I joined PN a few months ago. Smiley
With my last ISP I was all copper from the exchange Sad and now I'm fibre to a green box and copper from there.
So, my questions are
1. Which Green Box am I connected to?
2. Can I find out?
3. Does it matter?
The pub is two minutes from my home, although my home is two hours from the pub,
Fixes: 20
Re: Which Green Box? Can I find out? Does it Matter?
Go to the OR broadband checker, enter your phone number it will tell you which cabinet you are connected to.
it doesn't matter, as long as it works.
Browni
Aspiring Hero
Fixes: 45
Have a look here http://www.kitz.co.uk/adsl/cabinet-lookup.htm
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Leapy
Super (I think) Thank you both... I'm cabinet 67 Smiley
Can someone tell me, from the data is this good, bad, average or other? Roll eyes
Its all gobbledegook to me. Sad
PeeGee
You will be on the same copper from the cabinet as before. Whether it is "any good" is more easily guestimated by providing your modem-router stats, as the sync rate and SNRM values are a more reliable indication.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
Fixes: 6
FTTC is VDSL as opposed to your old service of ADSL.
With the latter it is the distance from your house to the Exchange which matters - with VDSL it is the distance from your house to the Cabinet.
Look at the VDSL results for details on your line. It shows a "good" line (A) and an "impacted" line (B) which gives an indication of what speeds you should expect.. You don't say what your actual speed is.
Leapy
I just ran some speed test on my fibre broadband and the results are...
Fixes: 33
How are you running these tests, wired or wifi? And what are you using to test?
A copy of the sync speeds from the helpdesk tab of the troubleshooting area of the router would help with diagnosis.
Leapy
@Mustrum wired to a Windows 10 desktop PC.
I just did the whole checking system and found a microfilter might be part of the problem as when replaced it went from 5mbps to 20mbps, which is what I normal get on my line (up to 35mbps).
I think I will replace all the microfilters tomorrow.
