Where's my FASTPATH gone?
- Where's my FASTPATH gone?
Re: Where's my FASTPATH gone?
12-09-2015 1:14 PM
12-09-2015 1:21 PM
Edit. It says within the article over on Kitz: http://www.kitz.co.uk/adsl/DLM.htm, but BT is unknown, so it maybe different.
12-09-2015 1:42 PM
12-09-2015 2:03 PM
Stability profiles: according to info on this forum PN did use the standard BTW option which maps to the BTOR speed option, So has a higher error rate threshold than the other two options
Looking at the very limited info from the stats , the upstream sync seems lower than it should be ,(assuming that the DS attenuation reported by the router is correct) Also if you where syncing at 75mbps you should of been able to download at lot nearer that speed 60+ mbps isn't good
what is your current BTW ip profile? http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Have you got a unlocked BT huawei modem ? as something like one of those would give full stats and you could also monitor the health of your connection that way
12-09-2015 2:12 PM
No I don't have any other equipment that I could use.
Below (hopefully) is what I was getting the day after PN went live with FASTPATH still on;
http://www.speedtest.net/my-result/4649957954
And this is what I've just got;
http://www.speedtest.net/my-result/4657683355
Sorry don't know how the get the speedtest pics on..!!
12-09-2015 2:42 PM
Quote from: DamBuilder Cheers. As a newbie here do PN staff not monitor/post at weekends?
Quick answer, No
Fuller answer, some Plusnet staff check in their own time.
It has become harder in the past few months to get PN staff to answer posts in this forum. Some topics never see a staff response.
12-09-2015 3:43 PM
Do you still have the BT Openreach modem, is it a ECI or Huawei brand ?
12-09-2015 3:55 PM
Quote from: deathtrap the link i gave should display this page http://i.imgur.com/sy344Kj.jpg, then after entering your telephone number you run the test, after the speedtest completes it should display the IP profile and your speed test result , It's the IP profile we needed to see ,
If I go straight to that page it does nothing but if I go to the http://speedtest.btwholesale.com/ page first it then takes you to the page you suggest when you press further diagnostics. Running it then gives the error I posted earlier "Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information." Tried three times with same error.
No BT wanted OR modem back so it's gone...
12-09-2015 4:11 PM
So BT Retail wanted their Home Hub back (router/modem one box setup)? If it was just a Modem that was supplied by the BT OR engineer When they installed the FTTC service (Which would require a router with EWAN port) that doesn't belong to BT Retail it is the active NTE so part of the circuit, but if the HH that could be different, but i have never heard of them wanting them returning before,very odd
Quote from: DamBuilder No BT wanted OR modem back so it's gone...
Ebay has some Huawei HG612 3B modems, but i wouldn't pay much more than £20 for one , unless plusnet will supply one, but there's a chance that it may be an ECI if they do, and they are not straightforward to unlock , also they don't work well with G.inp even though they are supposed to
I updated the link to what it should have been, it's a quicker way of displaying the IP profile (when it works for you)
12-09-2015 4:25 PM
Just checked your link again and it runs but with the same error as before.
12-09-2015 4:44 PM
Generally when the line is reset you start faster than normal, get a few errors then interleaving kicks in a few days later. If you can get G.INP this'll kick in a few days after that, otherwise the line will adjust speed accordingly in order to reduce errors. When the number of errors drop sufficiently and DLM finds the sweetspot for your line, interleaving will come off and you go back to Fast Path.
Tl;Dr version
Give it a week or so and it should sort itself out - there's no need to twiddle with router settings or whatever...
12-09-2015 4:50 PM
I hadn't actually tweaked anything on the router (other than the first reset and inputting of login details) which is what made it more frustrating lol...
Just one question; If G.INP is enabled on the router but the cabinet doesn't support it can this potentially cause problems?
12-09-2015 6:02 PM
But this wouldn't currently apply if connected to an ECI FTTC cab, do you happen to know what type of FTTC cab you are connected to?
The gaining provider wouldn't place an order for DLM to be reset by default , If it was reset it would be due to change of DLM stability profiles, assuming changing those would trigger it,
The only other way DLM would be reset is change of product type, ie 40/10 to 80/20 or vice versa
13-09-2015 8:32 AM
Quote from: DamBuilder Just one question; If G.INP is enabled on the router but the cabinet doesn't support it can this potentially cause problems?
It shouldn't make a blind bit of difference - pretty sure you mentioned an ECI cab earlier in which case they'll switch it on soon when they roll it out. Your modem will be ready when they do; the DLM is basically telling your router to ignore G.INP at the moment.
I'll agree with you about it being frustrating when you're not tweaking the router! I've been bitten a number of times in the past...
@deathtrap: fairly certain DLM reset is standard when migrating since BT OR won't know which DLM speed/stability profile or product you're on when they migrate you, they just reset the line. Plenty of cases of people moving from G.INP to interleaving when they change providers, meaning the line was reset.
Fairly certain only TalkTalk use a different DLM stability profile - BT and PN use the same for sure. I don't think the engineer knows whether you're 40/2, 40/10 or 80/20 at the time of migration so fairly certain the reset is just automatic.
Would be good if someone from PN could confirm...
13-09-2015 9:18 AM
Just noticed my down sync is now 87k which considering I'm on a 76/19 (which I assume is what people also call 80/20) connection seems rather weird lol
