When will you be upgrading customers with old plus net routers
- When will you be upgrading customers with old plus...
30-03-2016 2:22 PM
When will you upgrade your old loyal customers to the OneHub that you are now offering?
Very annoying as I singed up a new line with you just before you started shipping the new router and to get it I have to "renegotiate the contract with you" or buy a 5G one from a shop.
Re: When will you be upgrading customers with old plus net routers
30-03-2016 2:32 PM
If the router itself is good and causing no problems, look at getting a decent access point to do all the WiFi duties. It gives you the ability to disable the inbuilt WiFi, plug in the access point and locate somewhere that has the potential to offer better coverage too.
I just installed one of these for my brother the other day and I love them: http://www.broadbandbuyer.co.uk/products/23764-ubiquiti-uap-ac-lr-uk/
It's also power over ethernet, making locating it much easier (you don't need to sit it near a power source).
30-03-2016 3:18 PM
Linksys WRT120N does work with fibre. This is the model I am using currently. It doesn't automattically connect so you have to enter your details and primary and secondary IP addresses. It is cheap too at abut £10 to £21 on eBay.
Here is an EU seller selling one at £5. http://www.ebay.co.uk/itm/Linksys-WRT120N-300-Mbps-10-100-Wireless-N-Router/231867008295?_trksid=p21...
30-03-2016 3:48 PM
30-03-2016 4:25 PM
30-03-2016 6:10 PM
Buy one with a built in modem .
30-03-2016 7:30 PM
Quote from: Rippong I don't think that the new ones are rated too highly in WiFi performance either. They are all made to a cost point, so never going to offer world-class performance.
new Hub One wifi is actually fine, it's a lot better than the hub zero that's for sure. You can pick up a hub one or Home Hub 5 cheap on ebay
If you Like it, give it a
30-03-2016 11:09 PM
its all about what you want from it yourself and what you want to pay
Ps i have a ASUS dsl ac 68U ,, excellent on PN
01-04-2016 9:29 AM
Quote from: rongtw The HH5 is better ., any shop bought one is better
There is no difference between the HH5(a) and Hub One, same hardware & software!
01-04-2016 9:55 AM
01-04-2016 10:06 AM
Quote from: etdsaunders There is no difference between the HH5(a) and Hub One, same hardware & software!
Not exactly the same software (webpage branding + no BT Open Wi-Fi are the obvious differences, there may be others).
