When will my internet become active?
- When will my internet become active?
05-10-2018 1:15 PM
Re: When will my internet become active?
05-10-2018 3:07 PM
My phone line became active 2/10/2018 and told broadband would not be live until 16/10/2018. Hope yours is faster.
05-10-2018 3:18 PM
Welcome to the forums.
While you wait for a member of staff to confirm the date, you can do a quick check for yourself to see if the order has a completion date.
Have a look at the BT Wholesale checker site at https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Enter your phone number and look in the text below the results table.
It will say if there is an open order on your line and more importantly the date it is due to be completed.
05-10-2018 6:15 PM
Hi @Ts21
I've checked the order and it is showing that the service is now live. Does your phone socket have one or two ports on there? If there are, then please unplug your microfilter and plug your router direct into the phone socket on the wall.
If you are still having issues, please try and connect to the router to the test socket. You can view how to do this here.
05-10-2018 7:46 PM
06-10-2018 11:30 AM
Hi @Ts21,
Thank you for connecting to the test socket - I'm sorry to hear that this hasn't resolved the problem.
I've tested your line from this side but unfortunately the test isn't picking up the cause of the issue and just indicates that your modem is out of sync. Please report the issue here and let us know when you've completed it - we'll then be able to progress things further for you.
06-10-2018 2:33 PM
After resseting everything today it all seems to be working fine! Thanks for the quick help! Sometimes turning it off and on again repeatedly is the beat medicine apparently!
07-10-2018 3:22 PM
Hi @Ts21,
Thanks for getting back in touch - I'm glad to hear that everything's up and running for you now and I'm sorry for any inconvenience that you experienced whilst you were unable to use your connection.
Please let us know if there's anything else that you'd like to discuss.
