When will fibre upgrade be completed
- When will fibre upgrade be completed
23-05-2017 11:24 AM
Hi, I was told by a customer service agent that my upgrade was due to be completed yesterday (Monday 22nd). I received an email to let me know that my upload speed had changed and it was indeed 2Mbps as expected. Then nothing. I've heard nothing else and my download speed has remained exactly the same.
Can anyone give me some more info?
Thanks,
Rob.
Re: When will fibre upgrade be completed
23-05-2017 11:31 AM
p.s. I should add that my router reports connection speeds of 2Mbps up and 39,9 Mps down
23-05-2017 11:37 AM - edited 23-05-2017 11:38 AM
Sounds like your PlusNet profile ahsn't updated following the upgrade.
What does this https://portal.plus.net/my.html?action=data_transfer_speed (login required) say for Current Line Speed ?
23-05-2017 11:38 AM
Phone exchange:NEWCASTLE
Estimated line speed:40Mb (This may vary between 35Mb and 46.8Mb) - Checked on 2017-05-15 00:40:54
Current line speed:5.6 Mb
23-05-2017 11:57 AM - edited 23-05-2017 11:58 AM
Yup, as I expected , it hasn't updated to the Fibre speed. You could try contacting Customer support by chat or phone and explaining that your Current Line speed needs resetting following the Fibre upgrade or if you're lucky one of the PlusNet help team may spot this thread and pop in to reset it.
23-05-2017 12:10 PM
Hi Rob and welcome to the Community Forums.
I've had a check into your connection and like on your side I can see we are getting the full 40/2 to the router:
Downstream Speed | 40.0 Mbps |
Upstream Speed | 2.0 Mbps |
Can I ask then, the devices that your checking the speeds on, are they wireless?
I can see some issues with the connection and it being interrupted:
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 9 | 10 |
Errored Seconds | 7 | 9 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds |
0 | 0 |
It looks like since the fibre came active there has been 4 drops and even before that it looks as though there is an issue flaring up at times. If you haven't already I'd recommend plugging your router directly into your test socket as it will rule out internal wiring and help us narrow down where the issue is coming from.
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
It will take a day or 2 in the test socket to determine whether the drops stop and I'd recommend trying a wired speed test once in there to see if the through put speed is higher in this set-up.
Let me know how you get on.
Kind regards,
Ben
23-05-2017 12:15 PM - edited 23-05-2017 12:18 PM
@BD , surely, if it's synching at 40M down, the PlusNet profile should be set to an open profile ( or at least ~40Mb ) not 5.6 !
23-05-2017 12:22 PM
Hi, the drop outs were me restarting the router!
Also the router is already plugged into the master socket.
Thanks for your help.
23-05-2017 12:24 PM
Yep. I've just adjusted that now.
It looks like they're still provisioned on the shared WBC network, so this profile is more than likely causing the problem.
@RobP- please can you reboot your router and let me know how you get on?
23-05-2017 12:26 PM
Thanks, I'll reboot as soon as I get back from work at about 3.00pm
Thanks for all your help.
23-05-2017 12:27 PM
23-05-2017 2:47 PM
We're now at 36.6Mbps down and 1.88 Up
Thank you all for your help.
Rob.
23-05-2017 11:27 PM
