When will I get my expected speeds?
- When will I get my expected speeds?
- « Previous
- 1
- 2
- Next »
Re: When will I get my expected speeds?
01-05-2015 8:21 PM
Yes I've noticed that if i use 5ghz wireless i will get a true speedtest and consistent download, but if i use 2.4ghz wireless on anything it will not go above 22mbps down even though the wireless router is throwing out a max signal with a 9db booster aerial also connected to the router. very strange indeed
This is with no channel interference issues either, i'm actually putting out a stronger signal in the house than BT-Fon public wifi
Message 16 of 20
(362 Views)
01-05-2015 8:40 PM
Any suggestions on a decent router, I'm now getting issues with this one not allowing the laptop to connect wirelessly.
Maybe I should have went for the BT deal after all as the router at least looks reasonable
Message 17 of 20
(362 Views)
01-05-2015 8:54 PM
I'm using a TP-LINK TD-W9980 with a Huawei BT modem using the WAN port, and all is working fine (also has a built in VDSL modem onboard), others also use the Billion but i didn't like the idea of not having external aerials, I've removed the centre aerial and connected a TPlink 9db outdoor aerial that i have had for years on mine just to max out the wifi coverage on 2.4ghz in my place
Message 18 of 20
(362 Views)
01-05-2015 9:11 PM
I'd like to say I understand that
I'll do some research online for a decent one to buy as my older router gave me the same connection wired or wireless just about
Message 19 of 20
(362 Views)
02-05-2015 8:31 AM
Quote from: lzjoker I've removed the centre aerial and connected a TPlink 9db outdoor aerial that i have had for years on mine just to max out the wifi coverage on 2.4ghz in my place
Interesting, the TP-Link website specs for the "Antenna Type" state:
Quote Three 5GHz 5dBi detachable antennas (RP-SMA)
Two 2.4GHz 3.5dBi internal antennas
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 20 of 20
(362 Views)
- « Previous
- 1
- 2
- Next »
