When the WiFi is on my internet connection constantly flashes like something is downloading
MykeUK
This has happened twice now - the first time I changed my password and hid my router name from public searches which seamed to do the trick, but it's started doing it again tonight. Even if no phone or computer is using the internet and we're not streaming anything, when the WiFi is on the internet light flashes like the internet is in use, like something is being streamed / downloaded. This doesn't happen is the WiFi is turned off on the router.
Should be be worried by this? Is it just a connection test or check? Is there anything I can do (like MAC address filtering) just in case?
MykeUK
Re: When the WiFi is on my internet connection constantly flashes like something is downloading
I think an erroneous tablet I thought was off might be the culprit. Turned it off and everything seems to have calmed.
Fixes: 238
Glad to hear you managed to find the cause.
 Matthew Wheeler
