When do we get Fibre to the door?
- When do we get Fibre to the door?
03-10-2020 5:48 PM
Happy-ish Plusnet customer here but today, with the heavy rain the ancient copper wiring is creaking and about as useful as a wet bit of string!
When can we get Fibre direct to the door please?
See the attached image for my Thinkbroadband speed tests!
Re: When do we get Fibre to the door?
03-10-2020 6:16 PM
First, welcome to the forums.
As for FTTP, PlusNet are not currently offering it. maybe in the future. Is it even available on your line?
Check https://www.broadbandchecker.btwholesale.com/#/ADSL to see what is available on your line
But looking at your picture, you do appear to have a line issue. You should report it to: faults.plus.net
Include your picture of the downloads speeds etc in the report, its help the faults team, but also indicate it happens when you have lots of rain. Its probably a fault joint or some of your cable in water causing the issue.
