What type of Master Socket for Unlimited fibre extra
DOC1
Hi all
I have unlimited fibre extra and I have a Openreach NTE5A Master socket (Single Port) .Is this the correct master socket for fibre internet? any help would be much appreciated .
10 REPLIES 10
Legend
Fixes: 254
Re: What type of Master Socket for Unlimited fibre extra
@DOC1 Your NTE type is irrelevant really - it just means you will have to use an ADSL filter to connect.
DOC1
Ok John thank you, was just wondering as seen other peoples master plates and they was different. thank you.
Fixes: 418
@DOC1 If you do not like unsightly dangly filters OR if you have any extension wiring and want the best possible broadband speed then fit a filtered faceplate. All that you have to do is remove the existing front by removing two screws, connect any extensions to the extension output on the new faceplate, plug it in and replace the screws. Faceplates are not expensive, see  https://www.amazon.co.uk/Solwise-ADSL-VDSLFACE-SOL-Filtered-Compliant-Faceplate/dp/B00NBZKN30/ref=sr...
Once you have fitted this then no dangly filters are required but note that the hub must be plugged into the filtered faceplate, the extensions will only work with phones.
Legend
Fixes: 254
Thanks, @Baldrick1 - I had thought of that, but answered quickly.
DOC1
@Baldrick1
Ok thank you.
I think I will give that a go as I do have a unsightly dangly filter, And thanks also for the instructions on how to do it and the link.. much appreciated
DOC1
@Baldrick1
Hi there ,
I purchased the
that you suggested and fitted it this morning and I have now noticed that my SNR Margin(dB) upstream is lower from 15.4 to 7.3 is this normal or have I been sent a faulty faceplate .
Also looking at the screenshots I have attached does everything look ok .
Any help would be much appreciated .
198kHz
Fixes: 41
Look OK? Some people would give their right arm for figures like that! You must be virtually adjacent to the green cabinet.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
DOC1
Ok thanks.
Yes the green cabinet is just outside my street door approx.118ft
Fixes: 418
@DOC1
As @198kHz suggests, there are people who would give their right arm for this sort of performance. I have no idea why the upstream SNR has dropped, there's a myriad of possible causes but it's not something that you should worry about.
The connections inside filters of both types is basically the same. The DSL signal goes straight though and it's the phone output that is filtered.
DOC1
Ok well you have both put my mind to rest so I have nothing to worry about .
Thank you
