What speed should I be getting, is my IP profile stuck?
richpu
Can someone tell me what speed i should be getting as the current line speed is 80Mbps. BT test say ip profile is 32.41
i have the following screen shots.
info from webpage
info from the hub.
info from bt tests
Thanks in advance.
RichPu
1 REPLY 1
Fixes: 236
Re: What speed should I be getting, is my IP profile stuck?
@richpu
All the BT results and estimates indicate that your current line speed is not 80Mbps, despite this Plusnet claim.
Having said this your line speed is below estimates. It's possible that this is being caused by your internal wiring. The first thing to try is to remove the front from your BT master socket  (you may need to remove two screws) to reveal the test socket. Plug your filter in here and do a speed test using a computer connected to the hub with an Ethernet cable and see if that is any better.
