What's going on with my connection? Speeds all over the place (again!)
- What's going on with my connection? Speeds all ove...
27-03-2018 10:16 AM
Since the 21st March my download and upload has been all over the place, could my line and setting be checked please? I've had similar issues in the past that sort of went away, no faults were ever found. Generally I've been happy with plusnet and been with you for a few years, but I'll have to move on if this doesn't improve.
The first image shows the fluctuations in speed, green is download purple is upload. As you can see it's all over the place, but compare that to the 2nd which is from the start of the month, and the 3rd image which is from 20th Feb (speed tests taken every 45 minutes) you can clearly see something has changed.
Re: What's going on with my connection? Speeds all over the place (again!)
27-03-2018 10:21 AM
27-03-2018 10:25 AM - edited 27-03-2018 10:30 AM
No, hence the general fluctuations however this would be an issue all of the time and wouldn't account for the generally smooth speed graphs. The average speeds smooth this out, but you can clearly see over the past week smoothing it out results in graphs that don't match the past 6 weeks.
Here is the graph since midnight. No uploads, I was asleep and I have data showing about 60Mb *total* upload, about 500Mb total download over this period, mostly Hive for heating and alarm monitoring.
For completeness, the bottom graph shows the total traffic in and out of my plusnet connection, it can't go any other route this is the switch connected to WAN1 on my router.
27-03-2018 10:31 AM - edited 27-03-2018 10:32 AM
This graph, doesn't let me add another pic when editing post.
27-03-2018 1:42 PM
27-03-2018 2:26 PM
Thanks for checking.
I'm not using wifi.
27-03-2018 3:23 PM
No worries,
I'd make sure you've eliminated all the checks here next https://goo.gl/tu2WWu following that it would be a good idea to report a fault at http://faults.plus.net
Let us know when you have.
