What router can I get 4 fibre broadband
- What router can I get 4 fibre broadband
04-08-2015 11:43 PM
What router can I get for under £30 As the Plusnet one is no good thanks
Message 1 of 5
(910 Views)
4 REPLIES 4
Re: What router can I get 4 fibre broadband
05-08-2015 7:53 AM
welcome to the forum..
for under £30 you're unlikely to get anything decent.. http://www.broadbandbuyer.co.uk/store/fibre-routers/?sort=3#Content should give an idea of what's available, though the likes of amazon will have more range.
Message 2 of 5
(537 Views)
05-08-2015 8:17 AM
Do you need an all in one router VDSL2 or will it be coming of an openreach box?
Message 3 of 5
(537 Views)
05-08-2015 11:08 AM
Any
Message 4 of 5
(537 Views)
05-08-2015 11:14 AM
well if you have an openreach router i would suggest this to plug into it
http://www.ebuyer.com/391143-tp-link-tl-wdr3600-dual-band-n600-concurrent-wireless-gigabit-router-tl...
I currently use the and its been great flash with ddwrt and gives you lots of options to play with
Message 5 of 5
(537 Views)
