What is kci3
- Re: What is kci3
What is kci3
29-07-2017 3:37 PM
Re: What is kci3
29-07-2017 4:04 PM
Re: What is kci3
29-07-2017 4:31 PM
Re: What is kci3
29-07-2017 8:57 PM
KCI = Keep Customer Informed.
It's basically a notification send from a supplier to update on the progress of a particular activity like a provisioning order or fault.
In broadband/landline terms, KCI 3's are typically received when a provisioning order completes.
Re: What is kci3
29-07-2017 10:03 PM
Re: What is kci3
31-07-2017 12:29 PM
It looks like the cease order is stuck on our suppliers systems, so it didn't cancel. I believe that's in hand with our provisioning team and we're awaiting for updates from our suppliers.
In the meantime, the service is still active with Plusnet, but line tests are pointing towards a jumpering issue at the cabinet.
I've reported this through to Openreach to investigate further. Likely that once the cease order completes we'll need to reprovide the service, but this should give you service until that happens.
