What have Plusnet being doing to my connection
Fixes: 62
Note that sync to the exchange remained so these were PPP drops
690ec6c24699cc7b55845da1ff77de2a-01-09-2016
Fixes: 239
Re: What have Plusnet being doing to my connection
Based on the time it's most likely BT maintenance in your area.
 Matthew Wheeler
Fixes: 62
So why wasn't there a resync which is what usually happens when BT have been fiddling or is it different with fibre
Fixes: 239
It depends on where the work is being done.
With fibre you sync at the cabinet rather then the exchange so it's not uncommon for some types of maintenance to only cause a loss of PPP rather then sync.
 Matthew Wheeler
Fixes: 4
Same problems here Mathew & Old JIm.
04b97678b34a2501b89ebf5065af37ec-01-09-2016
Moderator's note by Mike (Mav): Fixed link.
RobPN
Seasoned Pro
Fixes: 4
@Oldjim
I had pretty much the same dropped packets indications on my TBB BQM at the same times as you (yesterday and today).  I'm on FTTP and I must have had at least one PPP drop during todays early morning packet-loss period as when I checked about an hour ago I was on a different gateway.  I've done some gateway hopping since I noticed so can't be more precise with the exact time of the beginning of the last session.
The 'red' period yesterday seems to coincide with the 'slowdown' experienced across most PN services, but AFAIK I didn't get any connection drops.
Edit: Typo
mikewalsh
I note that Shylock also reports loss of Internet at 2am
Regards Mike
