What cable for new Hub One
- What cable for new Hub One
05-06-2020 12:39 PM - edited 05-06-2020 12:41 PM
I need a longer Ethernet cable (around 10 m) for my new PlusNet Hub One fibre broadband router. It's difficult to match the description on the supplied cable with specifications on sites like Amazon. Are there specs that are a must (eg CAT5e) and others that don't matter?
Can't find this information on either the forum or Help and would be grateful for help.
Re: What cable for new Hub One
05-06-2020 12:43 PM
All that.you need is a cat 5E Ethernet cable, forget the rest
05-06-2020 12:55 PM
Thank you, Baldrick 1 for your lightning-speed reply! Simpler than I thought.
