Welcome increase
- Re: Welcome increase
Welcome increase
11-10-2015 8:41 AM
This post is somewhat sarcastic but.........
When I was upgraded to fibre the BT engineers did what they could to increase my speed as it was below the estimate. No success, and for about a year I have had about 17Mbps down and 2 Mbps up.
My next door neighbour, we share the pavement connection box, has recently upgraded to fibre with BT Infinity and my connection has now jumped to 28Mbps down 4Mbps up.
Coincidence ?
Coincidence ?
Let's be careful out there !
Message 1 of 9
(1,387 Views)
8 REPLIES 8
11-10-2015 9:45 AM
I don't understand what you are trying to suggest. Are you implying that BT openreach has given your neighbour special service that they wouldn't give you?
Message 2 of 9
(827 Views)
11-10-2015 1:19 PM
Sort of.
He complained to BT that he wasn't getting the advertised speed and they seem to have responded more proactively to his complaint. When I complained they did look but put it down to degrading alluminium cable so nothing they could do.
Message 3 of 9
(827 Views)
12-10-2015 11:35 AM
If your neighbour was with AAISP I could believe more pressure being put on the engineers (or at least AAISP doesn't take to being fobbed off so might just book another engineer) but if your neighbour is with BT Infinity then 'pot luck' is all I can suggest.
Quote from: Kremmen He complained to BT that he wasn't getting the advertised speed and they seem to have responded more proactively to his complaint.
What does puzzle me though is how work on your neighbour's line can improve yours. There's not all that much in common between the two. Perhaps the junction box was partially flooded (I've had that myself) or maybe a fault in the cabinet that required several lines to be reconnected.
Whatever the reason I don't think there's any need to be particularly suspicious about it. Just be happy
Message 4 of 9
(827 Views)
12-10-2015 11:54 AM
Shared cable from CAB to pavement box swapped from aluminium to copper?
Seems to confirm that for Plusnet users, Plusnet being part of the BT group is a disadvantage as they won't kick up a fuss to the same extent as other ISPs.
Quote from: Kremmen He complained to BT that he wasn't getting the advertised speed and they seem to have responded more proactively to his complaint. When I complained they did look but put it down to degrading alluminium cable so nothing they could do.
Message 5 of 9
(827 Views)
12-10-2015 2:21 PM
I'd be amazed if someone got Openreach to do that though.
Quote from: spoon Shared cable from CAB to pavement box swapped from aluminium to copper?
Surely they'd need to replace the entire cable bundle serving that property. That would mean disconnecting and reconnecting the entire street at both ends and of course there's the cost of blowing the cable (if they can blow copper bundles) and the cable itself.
It would explain the improvement at least in principal but surely would cost tens of thousands of pounds.
Message 6 of 9
(827 Views)
12-10-2015 9:51 PM
Openreach wont replace Aluminium for copper I asked when the Engineer that came to fix my issues discovered that my line as well as the entire area was Aluminium, even though he agreed it should be ripped out and replaced unless the line completely dies or i was willing to pay the cost myself which would run in the thousands i wouldn't get it replaced with Copper no matter how badly the line would degrade.
Message 7 of 9
(827 Views)
27-10-2015 3:00 PM
Sorry for not replying sooner. I wanted to see if it was a temporary increase.
My stats are now in the 28Mbps down and 5Mbps up.
The engineer did do some thorough tests when I had mine installed and the info was that:
58Mbps being pushed out of the fibre cabinet.
26Mbps being received at my local 100 connection pavement cabinet on a 800 metre ally cable.
20Mbps being received at the pavement box immediately outside my house also ally from the 100 box (100 metres).
19Mbps being received at my master socket (copper line to house)
My neighbour gets BT Infinity and all of a sudden I get this speed increase from an actual Speedtest.net reading of 17Mbps to 28Mbps.
Obviously I have no complaint but all I can think of is that they have boosted the fibre cabinet above the 58Mbps it was ?
Message 8 of 9
(827 Views)
27-10-2015 3:21 PM
58Mb being pushed out of the cab doesn't sound right the cab should be pushing out the maximum 80Mb but then drop due to your line distance to the cab etc, for example when the engineer came to try and sort out my issue he stated the maximum availability on the cab was 105Mb the cab was pushing out 80Mb ( the max that openreach allow) and that the speed once it hit the Ali line started to drop to my current 47Mb when it got to my home. i'm about 480m away from the cab and about 38m from the connection point in the street all is Ali sadly
so yeah it sounds like the Engineer maybe reset the cab so it was pushing out the right amount but i don't see how that would increase your speed, when the cab was pushing out 58Mb you were still only getting 17Mb a change to 80Mb being pushed out the cab wouldn't make a difference I would have thought but i'm not technical enough on such matters to know if it does.
Message 9 of 9
(827 Views)
