Weird speed results.
Pete11
Seasoned Pro
Fixes: 4
Having upgraded from 40/10 to 80/20 a couple of days ago (ticket 165647846) I thought I'd do a speed check and there's something not right. I have done screen shots.
Firstly, from BTW site
While the up speed is slightly higher (from usual 9.3) download speed is a little less than usual (37)
Test 2 from 'Which' site.
Not that far from BTW's
Test 3 from OOKLA
Note the difference in download?Huh
I couldn't do a 'Further Diagnostics' on BTW as I got error saying 'Timed Out'  Can anyone look into this please?  The speed is far less than expected.
Thanks.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 238
Re: Weird speed results.
Moderator's note:
Unhelpful cross-post removed.
Forum Moderator and Customer
Pete11
Seasoned Pro
Fixes: 4
Well, here I am again. Done another speed test (using BTW) and it's getting worse..not better.
Slow to say the least, even for a 40/10 never mind 80/20. Has anyone checked this yet? Because there's been no contact from anyone.
All the speed tests done wired, rebooted router, rebooted laptop and checked all this side (as much as I can).
rongtw
Fixes: 12
@Pete11 what browser are you Using ?  Firefox is known to give Odd test results and we are still awaiting a update on a fix from PN Lips are sealed
Yes i can confirm its still not working correctly Sad my test shows incorrect speeds
try a test here https://www.thinkbroadband.com/speedtest
Pete11
Seasoned Pro
Fixes: 4
@rongtw
I'm using Google Chrome (latest). Here's the result from the link you gave...and it's not good. Take a look.
If this is 80/20, I'll be moving back to 40/10 if this isn't sorted. Day 1 of cooling off period gone and counting. At least on 40/10 I was getting 37/9.3
Browni
Aspiring Hero
Fixes: 47
Your router stats would be helpful.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Pete11
Seasoned Pro
Fixes: 4
@Browni
How to find them would also be helpful. Not too sure with homehub1.
Browni
Aspiring Hero
Fixes: 47
From http://192.168.1.254 iirc they're under the troubleshooting->helpdesk tab, make sure to hide any personal info.
Pete11
Seasoned Pro
Fixes: 4
@Browni
Thanks for that, here they are...
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ65000985
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 12:30:38
6. Data rate: 15960 / 57675
7. Maximum data rate: 15967 / 56308
8. Noise margin: 6.0 / 5.9
9. Line attenuation: 22.2 / 20.4
10. Signal attenuation: 22.1 / 20.5
11. Data sent/received: 254.9 MB / 1.2 GB
12. Broadband username:
13. 2.4 GHz Wireless network/SSID:
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID:
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Disabled
22. MAC Address: 24:20:c7:78:c8:e6
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
You will notice that the last updated is 'Unknown'. Could this be the problem?
Pete11
Seasoned Pro
Fixes: 4
UPDATE
Well, I did yet another speed test this afternoon after a natter with a chap on 'Chat'...result??, take a look. This test was done wired.
According to chap on chat, my speeds should be around 58 to 60 down and 16 to 18 up...yeah right.
Day 2 of cooling off period and counting.  Angry
Pete11
Seasoned Pro
Fixes: 4
Yes, it's me again and still no further forward. Speed test done this morning at 08-20 and it's ridiculous.
Is this getting looked into?  Ticked off  I was getting far better results on 40/10, if this is 80/20 then come monday I'll revert back.
Pete11
Seasoned Pro
Fixes: 4
This test was done wired after rebooting router and changing laptop for borrowed brother-in-law's (just to rule out possible problem with my laptop). I shouldn't have bothered. This test was 12-30 this afternoon.
So nothing wrong with my system. Have sent results via the Diagnostics button (3 or 4 times now) and raised a fault ticket. There's been no contact from anyone at Plusnet, I don't know what's being done about these ridiculous speeds (because of the lack of contact) and I'm getting totally pee'd off with it. I'm now thinking of looking for a new supplier because you (plusnet) certainly haven't "Done me proud".  Ticked off  Ticked off
Pete11
Seasoned Pro
Fixes: 4
Just had BT bloke out and during tests found that on his equipment he was getting speeds of 68/19. On MY gear speeds were 27/8. I have changed the filter and getting less than 30 down with 9 up. After looking at router stats (and everything else) he said the problem is probably a faulty router. He noticed that under last update it says 'Unknown'. How do I go about getting the router changed?.
Pete11
Seasoned Pro
Fixes: 4
Doesn't matter...sorted it myself on 'Chat'. New router on it's way.
Pete11
Seasoned Pro
Fixes: 4
Well, here we go again. New router arrived and set up, WIRED connection to laptop, all connections correct and the result?
See for yourself...
Sort this PN please..I still have time to cancel if need be. For an 80/20 this is ridiculous. Engineer says socket to cab is fine but I doubt it very much. There is a problem somewhere.
