Weird speed results.
- Re: Weird speed results.
- « Previous
- Next »
17-01-2018 11:26 PM
The "engineer" has told you total nonsense. The GEA test clearly shows you were on fibre extra (80/20 profile). All the ports in the FTTC cab are capable of 80/20 unless you were on a faulty port. Your throughput speeds are low but that is another problem, possibly exchange congestion. So have PlusNet changed your product to 40/10 as I don't believe Openreach can do it directly, if so what are your speeds like now?
18-01-2018 8:58 AM
The engineer rang Plusnet, who in turn spoke to me and was decided to put me back to 40/10. But engineer did say that it was more likely to be a port problem. Plusnet did tell me though that as soon as the port problem was sorted, they would send me an email to see if I still wanted to go ahead with the upgrade.
As for speeds, they are back to a stable 37.6 and 9.4..just as they were before trying the upgrade. I don't think it was congestion because some of the speed tests were done around 2-30am others around 4am. to try and rule out busy times.
Growing old is inevitable...But growing up is optional.
- « Previous
- Next »
