Weekend Broadband Activation
Aspiring Hero
Fixes: 49
Re: Weekend Broadband Activation
Funny
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Thanks!
Unfortunately I'm still not able to actually use the internet. It's still showing an orange light with the broadband flashing red. What do I do now?
Fixes: 904
I’d recommend running through the checks here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 and reporting a fault to us at http://faults.plus.net if the checks don’t help. Let us know how you get on.
Yep same issue persists and testing e socket made no difference. I'm going to buy a cheap phone to test the dial tone tomorrow then report any faults
Okay so I didn't get a dial tone from the phone (including using the test socket) so I've just reported the fault.
Hopefully it won't take too long to fix, and thanks for the help!
Legend
Fixes: 168
I've tested your line and updated the fault ticket, if you can take a look here and reply directly to the fault ticket that would be great. https://www.plus.net/wizard/?p=view_question&id=155361035
Great thanks
Legend
Fixes: 168
That's all booked in for you, I've confirmed the date on the ticket. Let us know how the visit goes.
