Website does't load on Plusnet - could you try this site for me?
- Website does't load on Plusnet - could you try thi...
Re: Website does't load on Plusnet - could you try this site for me?
12-07-2018 10:07 AM
It may be a coincidence but I spoke to ii and it may be that the two issues are unconnected. I too am having the same problem. The original issue of April 28th is still unresolved and now additionally I am unable to log in to the main website at secure.ii.co.uk as well. I don't use a VPN so can't test that.
Bizarrely, nslookup works!?:
nslookup secure.ii.co.uk
Server: dsldevice.lan
Address: 192.168.1.254
Non-authoritative answer:
Address: 185.194.40.1
But when trying to access the webpage I just get:
"The connection has timed out
The server at secure.ii.co.uk is taking too long to respond."
As with the April 28 query, this may only be affecting Plusnet customers (and possibly some BT customers as well) but customers with other ISPs may be fine.
12-07-2018 10:13 AM
nslookup wasn't working for me about 30 minutes ago. They seem to have just fixed it about when you posted. I can now log in, although the original issue is still there. Can't view the ETF research option etc.
12-07-2018 10:26 AM
Yes, same here - main website is back up but the original issue is indeed still there.
12-07-2018 5:15 PM
Thank you all for getting back to me.
I've discussed this further with the person in our Network Team who has been chasing this up/investigating for us and have also been in dialogue with the sites engineers.
I have been advised we've investigated our network side of things and no routing changes have been implemented that would cause this problem from our side.
If the site was working in April/prior to April, at this point the best advice I can give really would be to contact the sites customer services making sure to outline when the problem started which based off of answers in this thread seems to have been some time towards the end of April(?).
13-07-2018 1:05 PM
Given that you've "been in dialogue with the sites engineers" have you explained to them what you have told us? And what has been their response? Have they accepted that the issue is something to do with them and, if so, have they stated that they are taking responsibility to fix it?
I spoke to them this morning and explained everything in a lengthy call and they inform me that the issue is with Plusnet as they have tested their site and it loads fine for them.
Also, we have not had an explanation as to why it is Plusnet customers that are facing this issue where customers of other ISPs are not.
13-07-2018 5:52 PM
I echo what morgan8 said.
13-07-2018 6:20 PM
That said, I'm not apportioning blame away from us with 100% confidence either. It does seem everything our side is good though.
Dialogue continues at a reasonably elevated level, however progress is slow because there's evidence from both parties that their house is in order.
13-07-2018 6:35 PM - edited 13-07-2018 6:44 PM
It seems to me that www3.iii.co.uk (or tdor-www-tddirectinvesting-co-uk.resolv.iicorp.uk or 185.194.40.22) has been blacklisted or blocked by a firewall or similar by Plusnet, or else a server with whichever provider that Interactive Investor uses has blocked a Plusnet server IP address.
I can't nslookup it using the Google nor the Plusnet DNS servers, however it works from my Plusnet connection if I use the ping.eu service. However traceroot via ping.eu fails after the following:
f5defense-ic-308524-ffm-b1.c.telia.net | 213.248.94.254 |
13-07-2018 6:53 PM - edited 13-07-2018 7:00 PM
I'm currently using a Daisy Wholesale connection and am getting the same problem I mentioned earlier in this thread (link)
This site can’t be reached
www.www3.iii.co.uk’s server IP address could not be found.
eta: I'm also using Cloudflare DNS so no Plusnet involvement whatsoever.
19-07-2018 4:00 PM
19-07-2018 4:16 PM - edited 19-07-2018 4:16 PM
Thanks Harry,
I'll be over my parents in an hour or two, so happy to test it on their PlusNet connection and will let you know how I go.
Will post back on this thread then and let you know.
19-07-2018 5:49 PM
Looking good here.
19-07-2018 8:22 PM
Works for me too. Thanks for your efforts.
I assume it maybe was a blacklisting or similar issue then? Might be helpful to know in case it happens again.
23-07-2018 12:48 PM
23-07-2018 1:18 PM
PlusNet may not necessarily know this as it appears it was down to a 3rd party (the website owners) to adjust something on their side, and they may not have disclosed what they did to PlusNet.
If PlusNet know what it is and are prepared to disclose it then fine, but of course anything to do with websites and security features etc. it might not be something they wish to post on a public forum.
