Webpages loading slowly this evening.
St3
Aspiring Champion
Fixes: 5
Loading webpages seams slow this evening, anyone else noticed ?
20 REPLIES 20
Sweeney47
Re: Webpages loading slowly this evening.
Probably something to do with the 50-60% packet loss that's happening because Plusnet are too incompetent to run the service they're asking us to pay for...
gogadgetgo
Yes, I've also got this problem. Is there a known issue or is it worth reporting?
slavo71
Same here in the NW.
teddysmum
Same here in Staffordshire , but my service has been awful since joining four weeks ago, today.
'We'll do you proud' When Huh
30FTTC06
Fixes: 4
hmmm
Resolver2 (0.0.0.0)                                               Sat Nov 19 19:13:51 2016
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
                                                  Packets               Pings
 Host                                           Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. 192.168.0.254                                0.0%    63    0.7   0.7   0.6   1.0   0.0
 2. lo0.central10.psb-bng01.plus.net             0.0%    63   12.1  12.4  11.7  14.0   0.3
 3. 411.be5.psb-ir02.plus.net                   23.8%    63   12.7  13.0  12.4  18.7   0.8
 4. 195.99.125.142                              20.6%    63   12.7  12.9  12.2  14.9   0.3
 5. peer2-et-10-1-0.telehouse.ukcore.bt.net     15.9%    63   13.3  13.3  12.7  16.9   0.6
 6. 194.74.65.42                                11.5%    62   12.8  13.3  12.7  17.8   0.8
 7. ???
 8. ae0.er02.cwwtf.bbc.co.uk                     6.5%    62   13.6  14.4  13.1  42.3   3.7
 9. 132.185.255.165                             12.9%    62   14.7  15.3  14.5  21.0   1.0
10. 212.58.246.78                               12.9%    62   13.6  13.6  13.0  14.2   0.0
SE
30FTTC06
Fixes: 4
@St3 DNS appears ellavated as well
Nameserver          	Response Time (ms)
                    	min/avg/max/stdev/retries
192.168.0.12        	1.15/1.15/1.16/0.00/0
192.168.0.15        	1.35/1.38/1.41/0.02/0
212.159.6.9         	12.66/14.74/18.21/2.53/0
212.159.6.10        	12.49/14.70/17.93/2.45/0
212.159.13.49       	12.66/14.60/17.44/2.28/0
212.159.13.50       	12.34/14.42/17.72/2.29/0
213.120.234.42      	12.87/13.48/13.97/0.42/0
213.120.234.38      	16.94/17.42/17.96/0.37/0
Hardly surprised with this dodgy weather!
30FTTC06
Fixes: 4
Opendns appears unaffected at this moment so I suspect some routes are Borked
nbk
Mmm I've been having problems since thursday with intermittent high pings, inability to connect to anything and the router disconnecting and struggling to reconnect. The huawei modem stays connected without error throughout (although I've given it a reboot tonight as a just in case).
apothecary1
Yes Slow tonight in N.Ireland
deadman2020
Speedtest says data throughput is fine but my ping is not as good (18) compared to it's usual lows (below 10). Webpages either load slowly or not at all. Google included.
rongtw
Fixes: 12
Ste Definitely summat up with PN network ?Huh
godsell4
I have been away for a week, so only noticed problems last night when I wanted to stream catchup TV, after a reboot of router and mode at 8PM, looked like things were fixed.
But now at 06:20 when I woke up, I find the PPP connection is down and will not reconnect. My TBB BQM chart shows it all dropped at about 12:20.
http://www.thinkbroadband.com/ping/share/f3b1e680dd6368bdf448fba966ac435c-20-11-2016.html
 Same for others?
And of course at this time there is no phone or chat support available at PN!
3Mb FTTC
godsell4
False alarm from me, rebooted the HG612 again and looks like it is working again.
3Mb FTTC
BrightonRock
Fixes: 8
Don't know it was/is the same problem but I was getting intermittent problems yesterday connecting to some, but not all, sites. For example, problems with NatWest, Thinkbroadband, and this site. So far OK today.
This is not a diagnosis but a description: It was as if there were several components on the network all providing the same service one of which was failing and I hit that particular one only part of the time.
