Webpages Loading times
- Re: Webpages Loading times
07-01-2019 4:40 PM
Hello. For some reason I keep having this issue whenever my bill is due webpages load really slow or not at all. Once I paid the bill the issue is till there. I had this problem before and I think it was a profile issue. Could you please fix this for me ? Cheers
Labels:
Message 1 of 5
(617 Views)
4 REPLIES 4
07-01-2019 5:09 PM
Sorry to hear you're having issues.
We've tested your line and we can't find any issues nor any profiles causing this.
Can you advise if you're connected over a wired or wireless connection when this happens?
Message 2 of 5
(605 Views)
07-01-2019 5:11 PM
A wireless connection. On my pc I have wired and it is the same issue. I’ll reset the router to see if that works.
Message 3 of 5
(604 Views)
07-01-2019 5:50 PM
Message 4 of 5
(590 Views)
07-01-2019 5:56 PM
Everything seems to be okay now. I know that when my bill is due it tends to direct me to the files billing website when I load a webpage but now it takes long for the webpage to load that it times out the connection. It is sorted for now though
Message 5 of 5
(586 Views)
