Webcam Upload Drop
- Webcam Upload Drop
Webcam Upload Drop
30-01-2016 10:44 PM
I have an IP webcam attached to my Technicolor 582n on Unlimited Fibre.
I have noticed that every 5 minutes the camera feed stops for a few seconds and starts again. I have had a look at the camera stats page and the connection seems to drop every 5 minutes and reconnect again instantly.
I'm not sure if it is a camera, router or connection issue.
I have checked and adjusted just about every setting i can think of in the router to no avail.
Can anyone suggest how i can monitor my upload connection to see if i can narrow the issue down?
Thanks in advance!
Thanks in advance!
Message 1 of 3
(804 Views)
2 REPLIES 2
Re: Webcam Upload Drop
31-01-2016 8:18 AM
You can set up a free ping test using the TBB web site.
http://www.thinkbroadband.com/ping
But I think this may be related to your camera's own settings. If you can set it with a fixed IP address i.e. don't use DHCP on it, try that see if things change. A quick search will tell you how to do this for your router and camera.
Message 2 of 3
(433 Views)
31-01-2016 10:22 AM
Quote from: lavvyheid I have noticed that every 5 minutes the camera feed stops for a few seconds and starts again. I have had a look at the camera stats page and the connection seems to drop every 5 minutes and reconnect again instantly.
Does the drop occur when the web cam is viewed form a local computer on your network, or only remote connections.
Also is the webcam wireless or hardwired.
Message 3 of 3
(433 Views)
