Wall mounting the fibre router
childwall43
I got a new router today when I switched to fibre. How am I supposed to hang it on the wall like the previous one, with an Ethernet cable sticking out of the back (the old one had the wires coming into the bottom edge).
11 REPLIES 11
rongtw
Fixes: 12
Re: Wall mounting the fibre router
you need to manufacture your own bracket to fit to wall  Embarrassed
deejayburnout
Quote from: childwall43
Dont fit it to the wall. A waste of 2 screws. Buy a 3rd party router. Much better
Eggs
I'm in the same situation.
The fibre modem sits neatly behind my desk on the wall.
But the new router is supposed to sit on something on its silly pink legs with loads of heavy cables spewing out the back tipping it over.
I've been looking for some low profile 90 degree ethernet cables but I think I'll go with a new router. Anyone recommend one with bottom entry ports?
I don't want a combined modem & router - just the router.
Also, the routers that plug into the fibre modem. Are these routers the same as those used with ADSL connections?
deejayburnout
I bought an Asus RT-N56U router and the cables go in the side. Far better performance than the PN one and looks nice to.
Would look nice on a desktop.
PeeGee
Quote from: Eggs
..... Anyone recommend one with bottom entry ports?
I would expect any half-decent wall mountable router to be mountable "lights up" = "cables down" - certainly, the TP-Link units I have do. Some will also mount with sideways cables/lights (not particularly useful, in my opinion).
To your other Qn., yes and no! Some ADSL and VDSL modem-routers can be configured appropriately, usually with a loss of one LAN port to provide the WAN port, though you have excluded these by preference. The router you need is usually referred to as a "cable router" and have five ethernet ports - one WAN and four LAN. For future proofing it is worth considering Gb ethernet, even if you cannot fully utilise it, and whether you also want to have 5GHz wireless now or in the future.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
orby
I found that vertically mounting the TP Link W9980 improved 2.4GHz wireless slightly, presumably because the antennas are internal (the 5GHz are the external ones annoyingly)
If I wall mount my W9980, the cables would be at the bottom but so would the antennas, surely it would be better with cables bottom, antennas top?!
PeeGee
I wouldn't want a desktop unit with antennae at the front and cables at the back, which would fit your suggestion, so it would need two different devices to cover the options. Whether the antenna is above or below is immaterial with respect to performance in normal circumstances.
Phil
Eggs
I find it frustrating all these cable routers seem to be geared to sit on a desktop. I much prefer - indeed insist - mine is tucked away behind my desk (and no it doesn't affect wireless coverage). Surely someone must do one which is designed to mount on a wall, with bottom entry ports similar to ADSL modems? Since my line speed is around 20mbs I wouldn't imagine using an old one would matter would it? I'd need 4 wired ports. I guest wireless network would be nice but not essential.
PeeGee
A (relatively) inexpensive TP-Link TL-WDR3500 would fit your spec - 1+4x fast ethernet, 2.4/5GHz both with guest network and wall mountable (cables & antennae down, lights up). The 3600 has 1+4x Gbe.
Phil
Eggs
Thanks for that Phil.
Looking at eBay they are going for about £40 delivered. So, they are the spec I want and within my budget.
Looks like there will be a bid going in.
Eggs
Quote from: PeeGee
Phil
Mounted my new TP-LINK N600 (TL-WDR3600) router today.
Very pleased. After wall mounting it (will happily mount with ports pointing up or ports pointing down) it sits unobtrusively out of the way behind my desk. No silly pink legs and no reams of cable spewing out on the back tipping it over. Much tidier.
Also, it is future proofed with 1000gb ports, has dual band wireless (2.4hz & 5hz) and even a separate facility for a guest wireless network. Beautiful.
Anyone want a silly Sagemcom 2704N router?
