Waiting for fibre connection
jaynej
I placed my order for fibre upgrade on the 5th June. Router arrived quickly and was easy to set up, but I've had no date given for the switchover and it's now 11 days and counting. Meanwhile I'm enduring broadband speeds of around 2.6 Mbps. Any clue how long this takes?
Fixes: 6
Re: Waiting for fibre connection
While waiting for a staff member to give you an answer you could try your phone number in the following. Does it say anything about an open order in the narrative.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
jaynej
Thanks for that, yes it says completion 19th June, so hopefully I only have 2 more days to wait. Plusnet could have just told me that in the first place!
Fixes: 195
Hi there.
I've checked your order and everything is due to go ahead on the 19th.
Apologies for the delay
 Matthew Wheeler
