WIFI not working, hard wired is (NB we have fibre) can anyone help?
- WIFI not working, hard wired is (NB we have fibre)...
06-06-2020 8:32 PM - edited 06-06-2020 8:34 PM
Hi
We have established that we can hardwire (computer works) but WIFI has literally just stopped working.
We have done the basics (restarting, power off & on etc).
Can anyone help?
Message 1 of 3
(455 Views)
2 REPLIES 2
Re: WIFI not working, hard wired is (NB we have fibre) can anyone help?
07-06-2020 11:09 AM
Temporarily disable security on your router (essential on router queries, you state what type you use);
see if your devices then connect.
Ensure the wifi button is enabled; all routers have button on them to disable wifi.
Message 2 of 3
(418 Views)
07-06-2020 11:41 AM
@CassnPhil That is a little weird, have you made sure that the Wi-Fi is turned on?
Message 3 of 3
(410 Views)
