Vodafone Suresignal v3 and Sagem Router
- Re: Vodafone Suresignal v3 and Sagem Router
19-05-2016 10:13 PM
Does anyone know how to get these to work together?
I have opened ports and assigned them to the sure signal device, that's about the limit of my knowledge and it still wont work. The sure signal says it cant connect to the internet. Vodafone are showing it as registered and active on my account.
20-05-2016 12:14 PM
Strange that you even need to open the ports really. Mine (different router) was just plug in and go but I know some people do need to manually forward the ports. There have been reports on the Vodafone support forum that VPNs interfere with SS - are using a VPN?
20-05-2016 12:50 PM
Hi @redgek, have you recently joined Plusnet from another ISP ? and did your SS work before ?
I have a theory (and it's only a theory!) that they (Vodafone) don't like a change in IP address from which the SS is trying to make a connection. It seems like they need to derigister and reregister the SS so that it will accept connection from the new IP.
As Andue says, all the port forwarding is not needed TBH I think it's just a ploy by Vodafone support (if you can call it that) to fob you off...
20-05-2016 4:06 PM
@redgek - Do Vodafone provide support on this type of hardware. Not meaning to pass the buck, but may be worth seeing if they have any ideas.
Matty
20-05-2016 4:57 PM - edited 20-05-2016 4:58 PM
Yes they do but it's all you'd expect from a company that Ofcom keeps slamming 😕
The entire SS system failed a few weeks ago and it took them five days to bring it back. They never did explain what happened and throughout the outage customers kept being asked to go through the standard troubleshooting process. But if the OP asks there some of the customers may be able to help.
20-05-2016 6:15 PM
Tbh, I thought i'd ask here because they are so frustratingly useless. It took them 2 attempts just to register and activate it at their side. They did mutter something about needing a static IP, but then didn't explain because it hadn't registered properly despite them setting it up. No-one has replied despite me posting on their forums. The port forwarding i did ass i found someone suggesting that was how they fixed theirs, but no joy, my device still doesn't connect to the internet. I will be contacting vodafone again.
