Vigor 2860
itian
Vigor 2860
I am looking at replacing my BT OR modem and plusnet router with Vigor 2860, does this modem\router work with plusnet?
I am a fibre customer
andew
Re: Vigor 2860
I've got a 2850, this has worked perfectly with bt, plus.net, and enta.net .  Cant see it being any different with the 2860.
It should be able to work with and without the openreach modem.
Andrew
happybunny
Re: Vigor 2860
Since moving to Plusnet Fibre in Feb I've had a Vigor 2860 running perfectly both with and without the BT OR modem.
JasonMassey
Re: Vigor 2860
Just adding to above, had a Vigor 2860n connected on Plusnet fiber for over a year.  2860n very stable, but ensure you upgrade the router to latest firmware.
