Vigor 2860
- Re: Vigor 2860
Vigor 2860
11-07-2015 6:52 PM
I am looking at replacing my BT OR modem and plusnet router with Vigor 2860, does this modem\router work with plusnet?
I am a fibre customer
Message 1 of 4
(886 Views)
3 REPLIES 3
Re: Vigor 2860
11-07-2015 9:28 PM
I've got a 2850, this has worked perfectly with bt, plus.net, and enta.net . Cant see it being any different with the 2860.
It should be able to work with and without the openreach modem.
Andrew
Andrew
Message 2 of 4
(546 Views)
Re: Vigor 2860
12-07-2015 9:42 AM
Since moving to Plusnet Fibre in Feb I've had a Vigor 2860 running perfectly both with and without the BT OR modem.
Message 3 of 4
(546 Views)
Re: Vigor 2860
13-07-2015 6:08 PM
Just adding to above, had a Vigor 2860n connected on Plusnet fiber for over a year. 2860n very stable, but ensure you upgrade the router to latest firmware.
Message 4 of 4
(546 Views)
