Very slow upload speed
timjade
I'm on Unlimited fibre extra with a plusnet hub one router but my upload is really poor. When performing a speed test (attached) with my PC directly connected to the router via Ethernet cable (or wireless) the upload speed stays at 0 for the first few seconds then climbs to about 0.5Mbps.
Could this be a faulty router?
Thanks,
Tim
7 REPLIES 7
Fixes: 419
Re: Very slow upload speed
This is unlikely to be a router problem.
At 16Mbps your download speed is also totally unacceptable for a fibre extra connection. What speed should you be getting? If you put your phone number in here it will tell you.  https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
You need to repeat this test with your router plugged into the BT test socket via a microfilter, that is the one you will find if you take the front off the master socket.
If that is also outside the limits quoted from the test results from the adsl checker then you need to report a fault.
adamwalker
Fixes: 221
Diagnostic tests have picked up on a fault with your phone line.
I've raised that straight to Openreach and have updated your account with more information here: https://www.plus.net/wizard/?p=view_question&id=190863547
We should have an update for you within a few days time.
 Adam Walker
timjade
Hi Adam,
Thanks for checking, how long does a fault like this typically take to be fixed?
Thanks,
Tim
adamwalker
Fixes: 221
The length of time it takes depends on what Openreach find as the cause of the issue. I want to be careful about setting an expectation with you so I'm going to hold back on advising about that until we know a bit more but I'm hoping it's all resolved within a few day's time.
 Adam Walker
adamwalker
Fixes: 221
Hiya Tim,
I've just checked and Openreach have cleared the fault back to us today after fixing a problem at the cabinet. I've tested the line and not seeing any issues now. Are you seeing any improvement on your side?
 Adam Walker
timjade
Hi Adam,
All sorted! 46Mbps down 18Mpbs up.
Thanks,
Tim
RandallFlagg
Fixes: 75
Glad to hear this, @timjade
Anything else you need, just drop us a line.
Best wishes
Dave
