Very slow unlimited fibre
- Very slow unlimited fibre
- « Previous
- 1
- 2
- Next »
Re: Very slow unlimited fibre
13-08-2018 4:07 PM
Hi Waz
Thanks for your reply I tried tweaking the router settings on my original Hub One to very little effect
just for form I tried some changes on this one including changing channel & temporary blocking 5ghz
range issue persists regardless, WiFi App shows PlusNet signal is head & shoulders above the neighbours
but as soon as I move outside the router room signal drops sharply still above the neighbours but not by so much
upstairs the difference is much more pronounced & why I bought the range extender as without it my fibre broadband is use less .
Looks like im gonna be in the market for a "proper" router soon Tweaking all these settings is really clever but for me
ultimately pointless & time consuming I just want what I had before fibre broadband out of the box seems like that's too much
to expect very disappointed with Hub One router performance, Plus net help is ok if a little long winded sometimes at least they are trying.
25-08-2018 2:45 PM
How lucky am I ? Blagged a secondhand BT HH6 off E Bay plugged in hooked up thanks to excellent
guides on here and its almost exactly the same as hub one speed is as good as it should
be but just like before the range outside the router room drops sharply verified by Wi Fi App on phone tried the usual
shifting router physical position changing channels disabling 5ghz very frustrating still using range extender to fill the hole Looks like im stuck with this, Even the all singing HH6 cant improve on PlusNet Hub One despite all the positive comments and reviews at least it looks more stylish than PN H1.
Really cant believe none off these issues happened when using the original Openreach Modem & Tecnicolour Modem
stuck behind TV for years giving faultless performance might see if I can source one on E Bay.
14-10-2018 5:46 PM
So Just over a month with my BT HH6 and after initial disappointment seems to have settled down
speed is a quick as you like (was never an issue) but no more annoying dropouts and range is consistant enough as well. I can finally bin the range extender, Rest of family using Apple tech report great speed & range (5ghz) all is well
Many thx to everyone on here for help suggestions and how to guides
- « Previous
- 1
- 2
- Next »
