Very slow speeds!!
molszewski
Very slow speeds!!
Not able to watch iplayer and pages timing out tonight. I have checked the speeds with BT Wholesale speed test and getting:
Download 0.40 Mbps
Upload 0.66 Mbps
Ping Latency 201ms
Can someone please check what the problem is?
rongtw
Fixes: 12
Re: Very slow speeds!!
Hi , firstly are the tests wired or WiFi ?  wifi is unreliable for speedtests
Second , what should you be getting ?   when you put your phone number in here ? https://www.dslchecker.bt.com/
and lastly this test shows what you are getting , http://speedtest.btwholesale.com/
This information will help staff find your problem Thumbs Up
Fixes: 77
Line tests don't show any issues at all so it does sound like you might be having an issue with WiFi.
I'd try following the checks here next https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
Please do keep us posted.
 Adam Walker
