Very slow speeds!!
- Re: Very slow speeds!!
Very slow speeds!!
18-02-2018 10:56 PM
Not able to watch iplayer and pages timing out tonight. I have checked the speeds with BT Wholesale speed test and getting:
Download 0.40 Mbps
Upload 0.66 Mbps
Ping Latency 201ms
Can someone please check what the problem is?
19-02-2018 5:48 AM
Hi , firstly are the tests wired or WiFi ? wifi is unreliable for speedtests
Second , what should you be getting ? when you put your phone number in here ? https://www.dslchecker.bt.com/
and lastly this test shows what you are getting , http://speedtest.btwholesale.com/
This information will help staff find your problem
21-02-2018 11:42 AM
Line tests don't show any issues at all so it does sound like you might be having an issue with WiFi.
I'd try following the checks here next https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
Please do keep us posted.
