Very slow speeds
- Re: Very slow speeds
Very slow speeds
07-11-2016 10:48 PM - edited 07-11-2016 11:05 PM
I'm experiencing very slow download speeds and quite frequently loose connection. I have checked it with many different speed checkers and all of them are showing same results. Even the BT one run with network cable rather than wifi shows same results
Download 1.92Mbps
Upload 9.68Mbps
Even Plusnet shows me that the line speed is very slow.
- Telephone number:
- Phone exchange:
- HAMPSTEAD
- Estimated line speed:
- 55Mb (This may vary between 80Mb and 80Mb) - Checked on 2016-09-30 22:58:02
- Current line speed:
- 2 Mb
I have disconnected and reconnected all the modems but no improvement. Can someone from support can have a look at this please.
08-11-2016 10:01 AM
Sure.
It looks like there was an issue with the profile on our side. Are you ok to log into your router and click disconnect/reconnect and test the speeds again for us?
Matty
08-11-2016 6:55 PM
Thank you, it worked, now 53.43 Mb/s!
09-11-2016 10:03 AM
Wonderful, thanks for confirming.
