Very slow fibre
- Re: Very slow fibre
Very slow fibre
26-06-2015 8:11 PM
Just had our FTTC fibre connection setup today. The engineer said we should get 24mbps, but 7 hours after he left we are still only getting 1.4mbps which is my old speed. The upload speed has increased to about 2mbps but when should I see an improvement in download speeds?
Message 1 of 5
(835 Views)
4 REPLIES 4
Re: Very slow fibre
26-06-2015 9:16 PM
It maybe that Plusnet forgot to increase your Line Speed as shown in the member centre at https://portal.plus.net/my.html?action=data_transfer_speed
It is probably still set to your ADSL speed which limits the downstream but not the upstream.
It is a common issue and needs a Plusnet member of staff to take a minute to set it and then you need to disconnect/connect your session in the router once the speed shows correctly on the above link.
Call Plusnet if the data line speed is sill showing the ADSL values and ask then to correct the current line speed .
Message 2 of 5
(521 Views)
Re: Very slow fibre
27-06-2015 11:09 AM
Message 3 of 5
(521 Views)
Re: Very slow fibre
28-06-2015 8:14 PM
Thanks for the help. Yes it's sorted now.
Message 4 of 5
(521 Views)
Re: Very slow fibre
28-06-2015 8:19 PM
It could take a while to build up but it's probably down to the planned maintenance,we have 0mbs.
Due to our location we only get 12mbs ish anyway, on fibre !!!!!
Message 5 of 5
(521 Views)
