Very slow fibre upload speeds
vindaloojim
My upload speed has dropped from a steady 17Mb/s down to 2Mb/s on a 80/20 sync rate.
Upload speed has been at 2Mb/s for a couple of weeks now. No changes have been made to my set-up.
In January I had slow download speed for two months until it was finally fixed by the Openreach engineer after three visits. I thought all was finally well and now my upload speed has dropped.
Can PN/ BT please investigate this ASAP as it is seriously affecting my internet experience especially streaming.
Fixes: 238
Re: Very slow fibre upload speeds
I can see you've raised a fault this morning but our testing isn't showing anything physically wrong.
You've mentioned your getting 2Mb/s which works out at around 16mbps.
At the risk of being pedantic are you sure you aren't getting your Mb's and Mbps mixed up?
 Matthew Wheeler
2MB/s works out as 16Mb/s (exactly synonymous with 16Mbps), we don't use mbps as a lower case 'M' implies 'mili' rather than 'Mega' so that would be slower than walking there with each bit in your pocket.
Still valid to ask whether there could be confusion between 2MB/s and 2Mb/s just to rule out a possible error.
Call me 'w23'
mlmclaren
Grin Grin Grin Grin Grin Grin Grin
vindaloojim
Quote from: Matthew
If you look again at my post you will see that the letter 'b' is lower case not upper case.
Surely 2MB/s is 16Mb/s
I am getting 2Mb/s upload speed down from 17Mb/s.
vindaloojim
Quote from: Matthew
That's strange, Matthew...
Quote from my fault ticket:
Our tests have found a fault with your broadband service.
You've given us all the information we need about your problem, we'll raise this to our supplier for investigation.
mlmclaren
Quote from: vindaloojim
Quote from: Matthew
Grin Grin Grin Grin Grin Grin Grin Grin Grin
Short and funny thread!
Whatever could happen next!
Fixes: 238
The tests picked up on a incorrect profile on the download which has now increased however aside from that the line looks perfect.
Your current profile is "0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off" and your upload is syncing at 20mbps.
In addition the BTW speedtest you carried out gave you these results
DownStream 71010
UpStream 15600
What speedtest are you getting your results from?
 Matthew Wheeler
rosslagerwall
I got my fibre installed today, and something seems very wrong with the upload speeds. I understand that speeds may be a bit variable in the first few days but this is hardly usable:
BTW test:
Download: 38.01  Smiley
Upload speed: 0.40  Sad
Ping latency: 19.63ms
The OpenReach engineer said my line was capable of 80/20.
I can't yet seem to log a fault on the fault logger.
Ironically, I got plusnet because of the 38/19 profile...
Fixes: 238
@rosslagerwall
Our suppliers haven't closed your order off yet so I can't test it at the moment but I'll try again later.
Was the engineer a Openreach engineer or a Kelly Communications engineer?
 Matthew Wheeler
rosslagerwall
Quote from: Matthew
@rosslagerwall
Openreach, I think. All he did was put a new Openreach faceplate on, plug in the Openreach modem, connect it to the router and it was all working, except for the upload speed. I am connected using ethernet.
vindaloojim
Quote from: Matthew
BTW
Speedtest.net
thinkbroadband.com
The upload speed fluctuates between 2Mb & 16Mb.
What was the incorrect profile that you mentioned synced at?
mlmclaren
Quote from: rosslagerwall
BTW test:
I get 66/20 currently by BTW test never gets more than 3mbps on my upload, but others like speedtest.net and ThinkBroadband get the full 18.7mbps
rosslagerwall
Quote from: mlmclaren
BTW test:
I have tried several different speedtests and locations and never got more than 2mbps.
mlmclaren
Oh OK... Well looks like you might need to wait for Openreach to close the order and then PLusnet can have a look and then if required rebook an Openreach engineer to visit and sort issue.
