Very slow fibre speeds!!
- Re: Very slow fibre speeds!!
10-02-2019 5:16 PM
Hi
So for the past few evenings my fibre speeds have been dropping to ridiculously low speeds of 5Mbs compared to the 40-60 Mbs that I regularly get at normal times during the day and usually the evening.have tried resetting router a couple of times but doesn’t make any difference ,and have used Ethernet directly into router but still getting same low speeds.dont know if any one could have a look at my line and whether or not this is due to conjestion in the evenings?
Chris
Chris
Message 1 of 2
(335 Views)
1 REPLY 1
11-02-2019 10:41 AM
Hi Chris,
I've just been running some tests and the diagnostics don't point towards any obvious issues.
If you're still seeing the same problem I'd go through some troubleshooting next: https://goo.gl/Rnae7N once that's out of the way it would be best to report a fault over at http://faults.plus.net
Let us know how you get on.
Message 2 of 2
(291 Views)
