Very slow fibre speed.
meyre68
I woke this morning to extremely slow speed. It took over a minute to check my email.
http://www.speedtest.net/result/5830989924.png
I've reset my router and done the other usual checks.
BT Wholesale test results
Download speedachieved during the test was - 0.62 Mbps
 For your connection, the acceptable range of speedsis 8.97 Mbps-12.82 Mbps .
 Additional Information:
 IP Profile for your line is - 12.82 Mbps
1480238043305497055
Fixes: 136
Re: Very slow fibre speed.
Our tests aren't showing any obvious cause but I can see you've called in and ordered a new router.
Let us know how you get on.
 Matthew Wheeler
meyre68
And it's back again. I did notice a noisey line sunday when my bro inlaw phoned me.
5853217034
Fixes: 136
I'd recommend raising a fault here so we can get that looked into.
 Matthew Wheeler
