Very slow fiber speeds and then no connection
- Very slow fiber speeds and then no connection
15-12-2016 11:13 AM
I been having very slow connection, then no connection (hit and miss) yesterday and today. Turned off and rebooted my router with no luck.
Could someone check my line out to see if it is a problem. User name duncums
Simon
Re: Very slow fiber speeds and then no connection
15-12-2016 11:39 AM
Testing your line isn't showing any issues, we're also not seeing many disconnections.
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 65.5 Mbps | ||||
Upstream Speed | 20.0 Mbps |
15-12-2016 11:56 AM
Mine has been going on for about a month, Had Plusnet since they started and never complained before but it is now awful. I cannot play Diablo at all!! TV goes on broadband too and it keeps dropping since I got the one box to try and fix it it's a joke >.<
15-12-2016 12:02 PM
Actually just checked, since October
15-12-2016 12:20 PM
Your line has been disconnecting a lot:
Test Outcome | Fail | ||||
Test Outcome Code | GTC_FTTC_SERVICE_1625 | ||||
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report | ||||
Main Fault Location | LN | ||||
Downstream Speed | 20.3 Mbps | ||||
Upstream Speed | 6.7 Mbps |
15-12-2016 12:51 PM
Thanks Chris it's done.
15-12-2016 12:52 PM
It dropped whilst doing it too 😕
15-12-2016 12:57 PM
That's great, thanks. It's been raised to Openreach and we should hear back within a couple of days, once we hear back we'll update the fault ticket.
16-12-2016 9:52 AM
Thanks Chris, I got home yesterday and Openreach had already been and fixed it!
16-12-2016 11:22 AM - edited 16-12-2016 11:23 AM
Network connected both ways wired and wireless, Switch router out to the stand alone BT modem and old router all working now. Must be a setting on the router can close thread now.
Simon
