Very slow Fibre Speeds
stan4th
Hello Tech Support.
I am on the 'Fibre Unlimited' package, I've been doing several speed tests but I am barely getting 1.5 Mb/s.
Can someone please look into this for me as its been a couple of days.
Thanks.
Fixes: 219
Re: Very slow Fibre Speeds
Your account had been changed onto fibre but the speed profile was still set at your old ADSL value.
I've changed this for you now so if you log into your router and disconnect then reconnect you should get better speeds.
Alternatively just reboot the router and that'll do the trick as well.
 Matthew Wheeler
stan4th
Thanks, that sorted it.
Fixes: 219
Glad to hear the speeds have improved.
Let us know if you have any further issues.
 Matthew Wheeler
stan4th
sorry to say the speeds have totally collapsed now.
Getting 0.49 down and 0.42 up.
Can you look into this urgently as I need to do some work this weekend?
Are you using wired/wireless? If wireless, can you try wired to see if that makes a difference.
Fixes: 219
I can see you've called in and my colleagues advised you on some wireless checks.
 Matthew Wheeler
