Very Slow Fiber speed after upgrade from ADSL
Fixes: 54
Re: Very Slow Fiber speed after upgrade from ADSL
Thanks for your message, @wmackay.
It looks like the Faults Team updated the ongoing ticket about 20 minutes ago and for your convenience you're able to access it below:
https://www.plus.net/wizard/?p=view_question&id=137627923
Please let us know if you need any further assistance at all.
 Owen P
wmackay
When the engineer visited yesterday he said he checked the ports in the cabinet and the line was syncing at 40Mbps when tested in at the cabinet and master socket. After he left I run a speed test and the speed is was 5.6Mbps and it is still 5.6Mbps this morning.
I am very disappointed the speed and the amount of time it is taking to get my speed up to my minimum guaranteed speed. I had 15Mbps when I was on ADSL and now that I have "upgraded" to FTTC I am getting a slower speed.
Fixes: 55
Hi @wmackay
I've tested the service again today and can see that your router is again only syncing at 6.4Mbps, however, there is no fault located on the line.
Test OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed6.4 Mbps
Upstream Speed6.1 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Radio Frequency IngressNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Cross TalkNot Detected
Estimated Line Length In Metres907.4
Upstream Rate AssessmentReasonable
Downstream Rate AssessmentLow
Interference PatternNot Detected
Service ImpactNo Impact Observed
Home Wiring ProblemNot Detected
Downstream Policing Discard Rate0.0
Customer Traffic LevelUpstream and Downstream Traffic Detected
TechnologyVDSL
DP TypeExternal
Profile Name0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
I spoke to our suppliers and they made me aware that the VLAN is hot - this was not stated on the above test. The agent I spoke to said that an auto fix is in place for this and should complete by 30/09/2019. they get fresh VLAN reports every Friday, so by a week today we should know more (though you will know before us if this has helped as your service will have sped up).
Kind Regards,
MoR
 MoR
wmackay
Thank you for the update and hopefully this fixes the issue.
How long has my connection been on a hot VLAN? And was it moved on because the line had a fault? Should openreach or plusnet knew this before a 2nd engineer came out for nothing? Will this happen again?
RealAleMadrid
Aspiring Champion
Fixes: 17
@MasterOfReality  So there are 2 faults in play here, a hot VLAN which restricts throughput because of congested backhaul and a ridiculously low downstream sync speed of 6.4Mbps when it should be somewhere near 40Mbps. In other words the Hot VLAN does not have any effect on the sync speeds so you need to investigate the poor speed as a separate issue.
wmackay
So am I right in thinking the hot VLAN would only lower my download speed but my sync speed would be at 40Mbps. But as my sync speed is only 6Mbps then that is from a fault on the line and the hot VLAN isn't a factor because of the fault?
But what is the fault on my line? The router is in the test socket, plusnet's GEA service test isn't showing a fault and the openreach engineer didn't find anything on the second visit, unless his report shows different? So what is the way ahead?
Fixes: 52
Hey @wmackay,
Thanks for coming back to us.
It's difficult to ascertain whether a hot VLAN would have been present at the point where we've previously raised faults - this is something that we'd look for, especially in terms of sync/speed issues, so I would hedge towards "No", but wouldn't be able to say for certain.
As things stand, you're in sync at 40mb/s, so if you could let us know the outcome of a speed test via a wired connection we'll be able to respond to those results accordingly.
Best wishes
 Maddy S
wmackay
I will get my son to check on it at the weekend as I am currently on holiday.  Hopefully it will be all fixed once I am back.
Fixes: 52
No worries, just give us a shout when you've completed those checks.
Have a lovely holiday.
Thanks.
 Maddy S
wmackay
But looking at the Broadband section on my account, this is what I had got;
Your broadband service
  • Product: Unlimited Fibre
  • Estimated Download Range: 31 - 40Mbps
  • Estimated Upload Range: 4 - 7Mbps
  • Minimum Guaranteed Speed: 30.9Mbps
  • Current Line Speed (Download): 6.1Mbps
So is my sync / line speed only 6.1Mbps?
Fixes: 84
Hi @wmackay,
I've checked your line and it's currently syncing at the full 40mbps, with the connection profile also being set at 40 from our side. It appears that the line speed figure on your account hasn't yet updated and I'm sorry for any confusion that this has caused. Please let us know if there are still any connection problems when you're back at the property.
 Emily D
wmackay
Thank you for the update. Hopefully it has been fixed and I should be able to update you at the weekend.
wmackay
Just got my son to check my speed and it is disappointingly of 5.6Mbps on ethernet and wireless with the router in the test socket.
wmackay
And this is the stats from the router.
Fixes: 54
@wmackay,
Well that's not very good. Can you update the ticket with another set of engineer slots I'm afraid we're going to have to go down the route of raising an escalation with Openreach on this one and keep pushing it up the chain until it's resolved.
 Joe
