Very Slow Fiber Speed
Lynger105
For the last 5 days my download speed is dropped to 15Mbps and my upload is about 5Mbps.
I have normally 56 Maps.
I spoke to operator but all they said that their speed check shows no problems as usual.
Help please.
Fixes: 205
Re: Very Slow Fiber Speed
Sorry to hear that.
Our tests aren't showing any issues.
Have you been able to try a wired connection?
 Matthew Wheeler
srv4kes
Yes, same here. My wifi printer has refused to print due to low signal quality.... What's Happening?
Lynger105
Yes but with the same result.
Fixes: 205
@srv4kes Can you try going through our wireless troubleshooting guides here?
@Lynger105 If the speeds are still poor over a wired connection I'd recommend raising a fault here
 Matthew Wheeler
srv4kes
Yes, and nothing has changed at home re: position of the router/printer. But exactly the same - something has dropped over the last 5 days.
Fixes: 162
@srv4kes
Do you experience any issues on a wired connection?
 Chris Parr
 Plusnet Staff
srv4kes
HI, phone (via wire) seems ok.
Computer and printer on wifi. Web searching is slow, but printer won't connect at all.
