Very Slow Fiber Speed
- Re: Very Slow Fiber Speed
16-11-2016 12:42 PM
I have normally 56 Maps.
I spoke to operator but all they said that their speed check shows no problems as usual.
Help please.
16-11-2016 12:54 PM
16-11-2016 12:55 PM
Yes, same here. My wifi printer has refused to print due to low signal quality.... What's Happening?
16-11-2016 12:59 PM
16-11-2016 2:24 PM
@srv4kes Can you try going through our wireless troubleshooting guides here?
@Lynger105 If the speeds are still poor over a wired connection I'd recommend raising a fault here
16-11-2016 5:04 PM
Yes, and nothing has changed at home re: position of the router/printer. But exactly the same - something has dropped over the last 5 days.
17-11-2016 11:44 AM
Do you experience any issues on a wired connection?
17-11-2016 2:48 PM
HI, phone (via wire) seems ok.
Computer and printer on wifi. Web searching is slow, but printer won't connect at all.
