Very Poor speed
- Very Poor speed
Very Poor speed
12-04-2015 5:46 PM
I used the speedtest@speedtest_domain username and suddenly the speed was 36mb/s.
Are you throttling my connection this much?
Re: Very Poor speed
12-04-2015 6:27 PM
Re: Very Poor speed
12-04-2015 7:02 PM
Re: Very Poor speed
12-04-2015 7:08 PM
Plusnet do not deliberately throttle anyone's connection, is the speed still the same?
Re: Very Poor speed
12-04-2015 7:11 PM
Re: Very Poor speed
14-04-2015 8:26 AM
Re: Very Poor speed
14-04-2015 9:41 AM
Re: Very Poor speed
14-04-2015 12:02 PM
Thanks for raising the fault ticket, that has been passed to the correct team to investigate and they should be back in touch by the end of tomorrow. Please accept our apologies for any inconvenience being caused by your lower speeds, we'll try and get this sorted as quickly as possible
Re: Very Poor speed
15-04-2015 9:44 PM
Its 21:43 and i am now getting 2.38Mb/s Download and 2.82Mb/s Upload
That is using BT Wholesale speed test.
Re: Very Poor speed
15-04-2015 11:26 PM
sorry i dont know how to resize the pictures. can someone from plusnet tell me why the Upload Speed stats of 0.8 Mbps are in green, surely that should be in red to indicate there is a major problem, Has something been set wrong at plusnet as its saying "We were unable to identify any performance problem with your service at this time" which is obviously wrong as there are major problems regarding the upload speeds.
