Vastly different speeds on different laptops
- Vastly different speeds on different laptops
- « Previous
- 1
- 2
- Next »
Re: Vastly different speeds on different laptops
04-03-2016 12:34 PM
04-03-2016 12:50 PM
Auto at 12:45pm
Download: 13.45 mbps
Upload: 9.91 mbps
Channel 1
Download: 18.36 mbps
Upload: 10.57 mbps
Channel 6
Download: 20.01 mbps
Upload: 10.52 mbps
Channel 11
Download: 17.66 mbps
Upload: 8.30 mbps
So if I switch to Channel 6 it is faster - even if its not anywhere near where it should be.
Any idea what this suggests is the problem?
04-03-2016 12:55 PM
As I explained earlier, an 802.11g 54Mbps connection will max out at around 22Mbps throughput so the 20Mbps download you got is not too far off the mark.
04-03-2016 12:56 PM
However, to be honest, it sounds like an issue with the wireless card in the laptop, I don't think that changing the channels will help much as the wireless seems to work fine on your other laptop.
Hopefully the 5G network will be better for you.
Edit: P.S. pwatson may be on to something here. If your laptop has 5G capability, I'd highly recommend trying that.
04-03-2016 12:57 PM
Is this something I can upgrade? (as I assume my other laptop must have a newer/better adapter to be getting a better download speed)
04-03-2016 1:00 PM
Whilst you are here, any idea why the auto (smart wireless) is giving me such reduced values compared to selecting a channel?
04-03-2016 1:03 PM
However, wireless N can provide a throughput of up to 50 Mbps (depending on wireless interference that is)
As for the automatic channel setting, it's also best to manually select a channel as automation can fail sometimes. If you download a program called "inSSIDer", you'll be able to find out which channel each wireless network in range is using, so you can change yours accordingly (avoiding the most used channels)
Hope this helps
04-03-2016 1:35 PM
This seems to be keeping my speed at a stable 20mbps (which sounds like the best I'm going to get until I update that wireless adapter)
Anoush - Can I suggest passing this information onto the tech support teams on live chat?
It seems to me that these two points (capability of the wireless adapter and channel interference) are things they should have known.
It was very poor customer service that I was told 'I don't know- see an expert' like I was - there wasn't even an attempt to help.
Mark.
04-03-2016 1:46 PM
Glad your getting to the end of your problem
The laptop WiFi card is probably onboard , but you can by cheap WiFi dongles that plug into your usb
04-03-2016 1:56 PM
Quote from: msowden22 Thanks to you both - I've downloaded that program and it suggests to use channel 11.
Mark.
I'm glad that you're getting the best speed out of your wireless card now. Knowledge of wireless adapters isn't a requirement for tech agents as it isn't something we officially support, however they should be aware of changing channels to avoid wireless interference. If you PM me your username I'll pass on some feedback on Monday as they should provide at least some basic advice.
- « Previous
- 1
- 2
- Next »
