VPN on Hub one
graphicmill
VPN on Hub one
Hi does anyone know what settings to use for port forwarding on Plusnet Hub one for VPN using windows server 2012r2, Plusnet support can't help!
1 REPLY
brookheather
Re: VPN on Hub one
Is this for PPTP VPN?  If so then you just need to select PPTP Server from the menu on the Port Forwarding page.
