VPN no longer working
rahopkins72
I use a VPN connection for work to access several clients. This has work previously but has now stopped working.
I have tried to different clients that are on different providers from home and none of them work. I've tested from a different connection and can get a connection so it doesn't look like an issue with my laptop or software.
I used to be able to connect via the VPN on my home connection but it has recently stopped. Router has been rebooted but this hasn't fixed the issue.
Please help
46 REPLIES 46
J1mbo
Re: VPN no longer working
Please post the detail of the type of VPN being used - SSL, IPSec, PPTP - give us something to work with.
rahopkins72
It is a SonicWALL GVC, not 100%sure but I belive it is an IPsec connection.
Here is a copy of the logs when I try to connect to different clients
2016/06/29 20:58:57:552 Information <local host> Dell SonicWALL Global VPN Client version 4.9.0.1202
2016/06/29 20:58:59:630 Information <local host> The connection "yyyyyy" has been enabled.
2016/06/29 20:59:00:693 Information 86.188.144.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 20:59:18:998 Error 86.188.144.xxx An error occurred.
2016/06/29 20:59:18:998 Error 86.188.144.xxx The peer is not responding to phase 1 ISAKMP requests.
2016/06/29 20:59:19:404 Information 86.188.144.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 20:59:38:998 Error 86.188.144.xxx An error occurred.
2016/06/29 20:59:38:998 Error 86.188.144.xxx The peer is not responding to phase 1 ISAKMP requests.
2016/06/29 20:59:39:420 Information 86.188.144.xxxx Starting ISAKMP phase 1 negotiation.
2016/06/29 20:59:45:252 Information <local host> The connection "yyyyy" has been disabled.
2016/06/29 21:00:04:985 Information <local host> The connection "zzzzz" has been enabled.
2016/06/29 21:00:05:767 Information 149.126.110.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 21:00:23:005 Error 149.126.110.xxx An error occurred.
2016/06/29 21:00:23:005 Error 149.126.110.xxx The peer is not responding to phase 1 ISAKMP requests.
2016/06/29 21:00:23:396 Information 149.126.110.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 21:00:26:181 Information <local host> The connection "zzzzz" has been disabled.
2016/06/29 21:00:29:485 Information <local host> The connection "wwwww" has been enabled.
2016/06/29 21:00:30:240 Information 86.53.27.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 21:00:48:006 Error 86.53.27.xxx An error occurred.
2016/06/29 21:00:48:006 Error 86.53.27.xxx The peer is not responding to phase 1 ISAKMP requests.
2016/06/29 21:00:48:427 Information 86.53.27.xxx Starting ISAKMP phase 1 negotiation.
2016/06/29 21:00:49:318 Information <local host> The connection "wwwww" has been disabled.
MattyC
Fixes: 46
Just out of interest, how long have you had this issue? I can see that you migrated over to our new network on the 20th, which could be the cause.
rahopkins72
I first Noticed it on the 23rd of June. I know i used the Sonicwall client from home before that but cant remember the date.
gh1978
I went on holiday last week and found I could no longer connect to the work VPN when I got home.  I wonder if it's a common issue.  I can't use teamviewer either (which is what I have a backup to the VPN).
I only need it for out of hours support from time to time, but I don't fancy driving to the 24 hour McDonalds to fix an issue.
Took the laptop to a friends house and the VPN works ok there via their internet connection.
I can ping the public facing IP that the VPN at the other end has associated with it.
Fixes: 394
There is a known problem with some Vpn routing when on the new network https://community.plus.net/t5/Broadband/VPN-fine-for-9-months-stopped-working-Jan/m-p/1301062/highli...
bobpullen
Fixes: 316
@rahopkins72, are you still having problems? If you are, can you please drop me a private message and I'll see what I can do to help. Thanks.
rahopkins72
Hi
Annabailey88
Hi Bob,
Hoping you can help as I'm having the same issue. I have previously been able to connect to sonic wall global VPN but haven't been able to for the last few weeks. The IT department at work have confirmed there isn't an issue with my laptop or the VPN.
bobpullen
Fixes: 316
@Annabailey88,
Can you please drop me a private message containing the following information?
This is the third SonicWALL issue I've come across now Undecided
Annabailey88
Hi Bob,
I've sent you a private message with the info you asked for.
Thanks.
arbgib
Hi all,
Just adding my two cents to say I'm having the same intermittent issue with a Dell SonicWall VPN and PlusNet.
It stopped working in April and then I managed to resolve the issue by restarting my router.
This time the problem was solved by restarting my router twice (for some reason).
I tried another PC on the network (wifi and wired) with no luck, and then managed to get in over mobile data on the same PC confirming it's something between my router and plusnet I would say.
Any advice would be great!
Thanks,
davide
I have same issue today.
Message is "the peer is not responding to phase 1 isakmp"
Works from phone hotspot so must be router/plusnet.
Anyone resolved this?
bobpullen
Fixes: 316
@arbgib @davide, the next time you're having difficulties can you please browse here and provide me with the first three octets of your IP address please? e.g. 80.229.16
