VPN issues
InterZoom
Re: VPN issues
There seems to be quite a lot of misunderstanding of @bobpullen 's questions, however this is most likely to be an MTU issue.
You'll probably find that if you tell your IT people that your router has an MTU of 1488 and show them this (albeit old) link, they will be able to sort you out.
Troubleshooting:
The Limitations of Traceroute & Ping
Latency: Connection "fast" but internet sluggish? Bufferbloat FAQ
Black Holes: Worth noting that the Plusnet Hub One router has an MTU of 1488 bytes.
