Evening.
Aside from the usual WiFi and rebooting issues the Hub One suffers with (yes I've tried all the fixes!) I'm having trouble connecting to my work VPN. I've had no issues up until the last few days.
My work uses the Global Protect client software which I understand is Palo Alto Networks.
The laptop connects fine via a mobile hotspot so I'm putting this down to an issue Plusnet's end rather than mine.
Everything else connects fine both wired and wireless.
I've also enabled the VPN option on the hub with no success.
Anyone else having the same problem?
Any solutions?
Thanks in advance.
