VPN Nightmare
- VPN Nightmare
VPN Nightmare
11-12-2018 3:55 PM
Any suggestions on accessing VPN through Cisco connect on my company laptop? Frustratingly I can’t get help from plusnet and everyone else in my office has no issues with this from their providers. I’m told by our IT team that the router plusnet sent may be blocking tunnelling. I have no idea what any of this means, I just want to be able to use my work laptop at home on occasion since I have a chronic illness which makes it hard to be in the office every day. Any help to put an end to this months long nightmare would be appreciated. Otherwise I’ll have to try my luck with BT! Thanks
Re: VPN Nightmare
11-12-2018 4:16 PM
Welcome to the forum.
I can't help with your VPN problem, hopefully another member who can will come along.
However, if you find that your Hub One cannot be used, before you consider paying cancellation charges and going to another ISP you should consider asking your work colleagues what router they use. Unlike some ISPs Plusnet are quite happy for you to buy your own and give the necessary setting up information here https://www.plus.net/help/broadband/broadband-connection-settings/.
This could be a much simpler and cheaper solution. .
Re: VPN Nightmare
11-12-2018 4:44 PM
Try logging in to your router and in the advanced settings check to see if
VPN
Re: VPN Nightmare
11-12-2018 6:43 PM
@juliamel AFAIK there is no basic problem with the Hub one and VPN. There are some issues with some vpn software and certain PN IP ranges. TBH I'm not sure whether it's a routing or geolocation problem but most of the time a change of IP fixes the problem. You could try leaving the router disconnected for about an hour , that usually forces a change of public IP. The other option is to request a static IP ( there is a one off charge of £5 ) as these are from a completely different IP range and do not suffer from the issues above.
Re: VPN Nightmare
11-12-2018 6:50 PM
Re: VPN Nightmare
11-12-2018 8:53 PM - edited 11-12-2018 8:54 PM
Have you checked the firewall settings in the members centre?
Broadband > Broadband Firewall.
Needs to be set to LOW or OFF.
Dan.
